Weight of car?
Old Oct 20, 2003 | 07:35 PM
  #16
QCKZ28's Avatar
You must have some serious weight reduction because my t-top car without me weighs 3440 and that was probably with between a half tank and three quarters of a tank....
just a little
but i still have ac/heat all my interior, power seat, and stereo.
Old Oct 20, 2003 | 07:48 PM
  #17
gb95zconv's Avatar
Mine wieghed 3815 with me in it a few weeks ago......that is without the spare and jack....no other wieght reduction has been done. I wiegh about 230 so the car is a shade under 3600.
Old Oct 20, 2003 | 08:17 PM
  #18
speed_demon24's Avatar
Mine weighed 3450lbs without me in it and a full tank of gas. This was done with full weight, no weight reduction at all.
Old Oct 21, 2003 | 08:45 PM
  #19
CamaroGuy22's Avatar
Originally posted by Mystic97Z
when i had my 97 t-top z dyno'd, it weighed in at 3650lbs with out me in the car...also, convertable are 300 lbs heavier due to more bracing,,, so ur looking at 3950 lbs w/o u in it.
You are incorrect. For Camaros the vert only weights about 80-90 lbs more than a coupe. I dont get why some people say oh man your car is so much heavier because the drop top, that is simply wrong. Many if not most Trans Ams weight more than my car due to the ground effects, more options etc. There is over 90 lbs of fluid in our cars. So if i were runnign low on gas, etc, my car would probably weight less than a similar hardtop with its gas and other fluids topped off. You get what i am trying to say? There isnt that much of a weight difference.
Old Oct 25, 2003 | 05:53 PM
  #20
ryan75's Avatar
Here is the reply that GM sent me:
Our research shows that the base curb weight for the 1995 Camaro is 3,480lbs.
The weight distribution of this 3,480lbs is: 1,940lbs in the front , and
1,540lbs. in the rear. Base curb weight is the shipping weight plus fuel to
capacity. The addition of optional equipment will change the curb weight. The
veh shipping weight is 3,400lbs, which is the weight of the vehicle without any
fuel, oil, or coolant.
(They didn't tell me how much a convertible weighs, but I replied and asked again.)
Old Oct 25, 2003 | 06:00 PM
  #21
ryan75's Avatar
You're probably exactly right-the main reason a convertible is a tad slower than a coupe is becasue of the drag coefficient. It's a little higher on verts than coupes (even with top up).
Old Oct 26, 2003 | 12:08 PM
  #22
Thank You, i can not find any info on the drag coefficient of either .
Check this out for the weights:
http://autos.msn.com/research/compar...=t6603&v=t6605
The curb weight for a 94 Z28 Auto Coupe is 3521.
The curb weight for a 94 Z28 Auto Convertible is 3609.
Old Oct 27, 2003 | 12:31 PM
  #23
ryan75's Avatar
HERE IS WHAT GM E-MAILED ME:
We have researched your request for the weight differences between the 1995
Chevrolet Camaro coupe and convertible. Please see the list below for requested
information.
Camaro 2 Door Coupe: 3,251 pounds
Camaro 2 Door Convertible: 3,342 pounds
Camaro 2 Door Coupe Z28: 3,390 pounds
Camaro 2 Door Convertible Z28: 3,480 pounds
Thank you again for your message and for making Chevrolet your vehicle of
choice.
Old Oct 27, 2003 | 05:13 PM
  #24
information.
choice.
Exactly, those weights are manuals, i was quoting autos. Thanks for doing some hw like i did, instead of pulling numbers out of your *** like alot of other people do.
oldschool
Feb 9, 2016 09:21 PM
bossco
Nov 29, 2014 10:18 AM
USAirman93
Nov 24, 2014 03:37 PM
wytblur
Mar 2, 2003 03:40 PM
sleeperZ96BT
Aug 29, 2002 01:10 AM
