A website with detailed instructions on changing opti??
Old Apr 1, 2008 | 04:43 PM
ToocoolZ28's Avatar
I seem to remember a site a while ago with pics and instructions on replacing the optispark. I cant find it now and have a few questions.
1. Do I have to pull the hub off the the end of the crank shaft? If so, is it bolted or just pressed?
2. Which way does the seal for the shaft off the cam supposed to face, in or out? Any pics anywhere?
I replaced this about 8 years ago and forgot what a pain it is, I'm also trying to replace the plug wires without dropping the crossover pipe (Borla 3" Y-pipe) the studs are pretty rusty and I dont think they will come out.
Thanks for ANY help.
Ron
Old Apr 1, 2008 | 05:16 PM
ss.slp.ls1's Avatar
Helps to remove radiator fans, though not necessary
Remove balancer/dampener (not entire hub)
Remove water pump (may require unbolting the air pump, just let it hang)
Remove old opti, replace, index it correctly.
These may help (courtesy of Shoebox):
http://shbox.com/ci/balancer_hub.jpg
http://shbox.com/ci/water_pump.jpg
http://shbox.com/ci/opti_mounting.jpg
http://shbox.com/ci/ci411.jpg
http://shbox.com/ci/ci276.jpg
Old Apr 1, 2008 | 07:43 PM
Pontiac_97's Avatar
drain radiator before pulling the water pump. also pull the sensor on the front of it to let out more coolant. makes it less messy when you actually pull it off. there is a little plastic drain valve that unscrews at the bottom of the radiator
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
meissen
Jun 1, 2015 07:59 AM
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
