Low Compression pistons with 58cc heads?
Old Apr 1, 2008 | 04:15 PM
jap901's Avatar
Question Low Compression pistons with 58cc heads?
Hello what is the lowest compression pistons you can get for 58cc heads?
I seen they have them down to 8.5 for 383 stickers but I am looking for ones for a 350.
can you mill the piston tops like they do on diesel engines?
thanks Jim
Old Apr 1, 2008 | 04:54 PM
evilundisguised's Avatar
There are alot of off-the-shelf pistons at around -18 or -20ccs... but there are many other factors affecting compression ratio.
I don't know why the head volume would make a difference if you're trying to lower compression - problems could arise when trying to raise it (using dome pistons).
Old Apr 1, 2008 | 07:02 PM
jap901's Avatar
Ok say I am considerion using a turbo set up. the lower I lower my compression the more boost I can run, but because my head volume is 58cc the lowest I can get is 9.2 compression and I like to get it to 8.0 to 8.5 compression.
Old Apr 1, 2008 | 07:10 PM
GreasyB's Avatar
Head volume means alot to compression. Are you saying it doesnt matter?
Old Apr 1, 2008 | 09:15 PM
No, I was wondering why he's thinking there's a limitation imposed by head volume on his choice of low-compression pistons.
The "for 58cc heads" he stated in his original post was what I was referring to.
Old Apr 1, 2008 | 09:23 PM
jap901's Avatar
Never mind the 9.2 compression will be fine for a street turbo setup.
I should have read alittle more b4 posting.
Old Apr 1, 2008 | 09:28 PM
Without knowing anything about your engine or what variables you're considering... with stock bore, rod length, compression height, gaskets, deck height, you could use a set of 20cc pistons to get down to ~8.8:1.
To go much further than that, you'll probably need some custom pistons.
Old Apr 1, 2008 | 09:57 PM
jap901's Avatar
I am for sure which way I want to go with the engine.
I like to have around 500 to 600 fwhp with great torq in the low to mid range if I deside to turbo.
The car is going to be more of weekend & car show car. it may see the 1/8 drag strip once just to get a time on it.
It is a 95lt1 from a TA with a 6 speed trans that will be put in a 96 mustang.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
parkers Z28
Mar 11, 2016 08:14 PM
pimpss96
Feb 12, 2015 01:28 PM
