Weak spark from coil!!
Old Dec 31, 2010 | 02:51 PM
Ashie93Z28's Avatar
Angry Weak spark from coil!!
My 93 Z28 has a new opti , and coil. Yet there is still not enough spark coming from the coil to even start. Anyone have any suggestions?
Old Dec 31, 2010 | 03:27 PM
Guest47904's Avatar
Guest
Re: Weak spark from coil!!
Connection issues between pcm and ICM or ICM and coil. Could be the ICM. What problem caused you to replace the OPTI?
Old Dec 31, 2010 | 08:55 PM
camarorz28's Avatar
have you ohm the coil? could be a bad coil. check the primary and secondary with a voltmeter. If your getting spark after to the distributor from the coil , your coil must be bad.
http://shbox.com/1/coil_testing.jpg
Old Jan 1, 2011 | 03:59 PM
Ashie93Z28's Avatar
The opti was replaced because of stuttering and surging issues and generally inconsistent performance before she died. So new opti and coil, haven't checked the ICM yet.
Old Jan 7, 2011 | 08:14 PM
Ashie93Z28's Avatar
It was the ICM.
ad356
Apr 16, 2015 05:38 PM
greenzee28
Mar 26, 2015 09:13 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
tbyrne
Aug 16, 2002 01:12 PM
