Water pump shaft seal
Old Sep 15, 2005 | 09:53 PM
poolkitman's Avatar
If this seal leaks it would be leaking oil not coolant - correct?
Old Sep 15, 2005 | 10:50 PM
Lt1t56's Avatar
Re: Water pump shaft seal
Correct
Old Sep 15, 2005 | 11:12 PM
poolkitman's Avatar
I thought so since the pump is cam driven - just another place to investigate for the mysterious occasional drip (hard to see in that area!)
Thanks again.
Old Sep 15, 2005 | 11:15 PM
It is hard to see in that area, but a leak there can put out a lot of oil.
Old Sep 26, 2005 | 11:43 PM
WinkleTheMoose's Avatar
I'm leaking a qt. of oil a week, is that a lot should I replace that seal? I think so! Is it hard to do so would be my question, can I do it without a lift?
Old Sep 26, 2005 | 11:51 PM
Z95m6's Avatar
Yes you just remove the waterpump and replace the seal.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
KYWes
Apr 15, 2015 07:28 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
