water pump gear after ewp?
Old Feb 24, 2007 | 04:07 PM
maro z28's Avatar
What happens to the water pump shaft and gear after you put in an electric water pump? Are the shaft and gear left to free spin, or is it totally removed? I head the water pump gear acts as the damper for LT1/LT4 engines. Would removing the gear then call for an aftermarket damper?
Old Feb 24, 2007 | 04:25 PM
evilundisguised's Avatar
They can stay and spin, or you can pull the timing cover and remove them. I left them in place, as many people have done, since I had no desire to take apart the timing cover at the time.
Old Feb 24, 2007 | 04:29 PM
maro z28's Avatar
Is there a need for a damper if you remove it if you're gonna spin past 6000?
Old Feb 24, 2007 | 04:38 PM
I've never heard that the wp drive acts as a damper... And I can't believe that it has anything to do with the balance of the rotating assembly. But, I've been wrong before.
Old Feb 24, 2007 | 04:44 PM
maro z28's Avatar
I can't find where I read that. I'll keep searching. I'm planning on getting a Cloyes Hex-A-Just timing set anyway, no gear to drive the wp gear. I just wonder if a damper is in order.
Old Feb 24, 2007 | 04:48 PM
mdacton's Avatar
No damper...grind the cover for the hex adjust...also the hex adjust has to be moddified to fit the opti
Old Feb 24, 2007 | 04:50 PM
aboatguy's Avatar
Remove the waterpump drive and use your stock damper you'll be fine.
Old Feb 24, 2007 | 05:01 PM
maro z28's Avatar
awesome, thanks fellas.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Zone
Jul 29, 2002 07:43 PM
