Electric Water Pump... Question...
Old Feb 22, 2007 | 11:12 PM
JooneJune's Avatar
I Am ready for install, But I was wondering about the little drive comming out of the timing cover. Should i take this little bugger out and try to cap it off? I don't thin I would need this WP Drive anylonger would I?
Old Feb 22, 2007 | 11:35 PM
Z95m6's Avatar
You can take it off and remove it but thats a lot of extra work unless you're going to remove the timing cover for something else.
Old Feb 23, 2007 | 10:48 AM
Critter's Avatar
also you might want to run a led to somewhere in the cab so you know the water pump is getting power and running. if the light goes off kill the car!
Old Feb 23, 2007 | 10:53 AM
njenson's Avatar
yea and in a hurry... not something that would keep me from doing it though. You just have to be a little watchful, and have the proper safety equipment
Old Feb 23, 2007 | 11:01 AM
SS Joe's Avatar
I left the stub sticking out of the timing cover until later, when I built the 383...then I removed it, and did away it and the stock type timing set. You have a lot more choices in timing sets when you remove the shaft completely. As long as you aren't doing at least a cam swap, might as well leave it in for now.
Old Feb 23, 2007 | 11:32 PM
6089wally's Avatar
I Had Mine Welded When It Was Off The Engine. I Had To Have The Waterpump Welded Also As The Plug That Was Included Did Not Fit The Hole.
Old Feb 24, 2007 | 08:54 AM
SS Joe's Avatar
Was your pump a Meziere? Mine fit fine. On the hole in the timing cover, I found a freeze plug that was close (a little oversize), did some grinding on the edge, and tapped it in with some silicone to prevent leaks.
Old Feb 24, 2007 | 02:12 PM
JooneJune's Avatar
Yes Meziere. I figure i won't need the little drive... If I can get to it I will. I may be swapping out the timing chain considering I'm doing a rebuild. Thanks!
Old Feb 24, 2007 | 04:32 PM
evilundisguised's Avatar
A 1 1/8 "deep" freeze plug fits the wp housing perfectly - a bead of silicone and something to tap it in flush, and you're set.
Old Feb 24, 2007 | 04:41 PM
aboatguy's Avatar
One of the benefits of an EWP is now you can use double roller timing sets vice the expensive LTX timing set.
Old Feb 24, 2007 | 04:49 PM
97WS6SCharged's Avatar
True, but you will have to clearance the timing cover in most cases.
Old Feb 24, 2007 | 05:02 PM
aboatguy's Avatar
I guess my 95 and my buddies 93 are the exceptions!
Quickss96
Jan 29, 2016 05:56 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MikeWhitener
Aug 2, 2015 06:17 PM
Boss002
Jul 9, 2015 03:33 PM
