Which water pump is everyone using?
Old Aug 10, 2003 | 02:41 PM
Myxtreme1's Avatar
I've been looking at water pumps since I have mine off right now and I've seen there are several. Which one is everyone using?
Old Aug 10, 2003 | 02:52 PM
AsianSensation's Avatar
Not much of a choice since we have reverse cooling. It's either going to be a stocker, CSI, or Meziere.
Old Aug 10, 2003 | 02:55 PM
94GrayV6's Avatar
See sig.
Old Aug 10, 2003 | 02:59 PM
Myxtreme1's Avatar
Is anyone using a reman from an auto parts store? Thats all I have ever used and never had a prob.
Old Aug 10, 2003 | 03:01 PM
Myxtreme1's Avatar
Originally posted by 94GrayV6
See sig.
How hard is the Meziere install?
Old Aug 10, 2003 | 03:04 PM
funina91ss's Avatar
Aolt of guys go with the electric pump when there stocker craps out. I have a csi and have no complaints with it.
Old Aug 10, 2003 | 05:50 PM
InjectedSS's Avatar
get the CSI!!! NO regrets here! its cheaper, and you dont have to cut your cooling fans to install it its a VERY NICE UNIT IMHO! hell i got one just so i could bypass that damn waterpump shaft so i dont ever have to deal with that ghey *** seal ever again
Old Aug 10, 2003 | 06:47 PM
BLK96Z28's Avatar
I just put on a NAPA reman. $98 with lifetime warr. Works well so far, but the car runs hot when A/C on. Even with my fans on high.I don't know why, it never did it with the original.
Old Aug 10, 2003 | 07:11 PM
Myxtreme1's Avatar
Where did you get yours?
Old Aug 10, 2003 | 07:26 PM
12SCNDZ's Avatar
CSI, and I can tell you that I have a HARD time getting the car up to 180 degrees!
Frank
Old Aug 10, 2003 | 07:31 PM
Derrick Redd's Avatar
Meziere HD.
Old Aug 10, 2003 | 07:40 PM
12SCNDZ's Avatar
CSI and Mez each have their advantages/disadvatages. The CSI needs the pump housing modified, the Mez has pump motor to fan shroud clearance issues. In either case, you'll need a 1LE intake bellows to do away with the silencer tube. I've seen alot more posts about problems with the Mez.
Frank
Old Aug 10, 2003 | 07:58 PM
InjectedSS's Avatar
here u go
SUMMIT RACING
CSI-901LT1 Water Pump Conversion Kit Fot LT1 Chevy (1993-1995) $135.95
Old Aug 10, 2003 | 08:44 PM
Myxtreme1's Avatar
Thanks again for the info guys. I'm gonna think about doing the e-pump conversion.
Old Aug 10, 2003 | 10:31 PM
Draco's Avatar
Frank
You can still keep your stock intake elbow, you just need to cap it off with something like the bottom of a shampoo bottle.
I run a CSI pump on my setup and couldn't be happier. The temp doesn't change by more then 1 degree during a full 1/4 mile pass.
