Which water pump is everyone using?
get the CSI!!! NO regrets here! its cheaper, and you dont have to cut your cooling fans to install it
its a VERY NICE UNIT IMHO! hell i got one just so i could bypass that damn waterpump shaft so i dont ever have to deal with that ghey *** seal ever again
CSI and Mez each have their advantages/disadvatages. The CSI needs the pump housing modified, the Mez has pump motor to fan shroud clearance issues. In either case, you'll need a 1LE intake bellows to do away with the silencer tube. I've seen alot more posts about problems with the Mez.
Frank
Frank
Originally posted by Myxtreme1
Where did you get yours?
SUMMIT RACING
CSI-901LT1 Water Pump Conversion Kit Fot LT1 Chevy (1993-1995) $135.95
Frank
Frank
I run a CSI pump on my setup and couldn't be happier. The temp doesn't change by more then 1 degree during a full 1/4 mile pass.
