water pump drive shaft wobble!!
Old Apr 6, 2010 | 08:01 PM
z28beast's Avatar
ok so i removed my old water pump today to replace the seal and i noticed that the shaft coming out of the engine for the water pump has a little play in it...i can wobble the water pump shaft back and forth a little but not in and out...also the seal is soaked in oil and im sure its leaking...is this normal or is the seal just really blown out or something???please help im really nervous as im in the middle of my first attempt at an engine pull
Old Apr 6, 2010 | 09:14 PM
If the shaft wobbles enough it could ruin the seal. No seal leakage is normal. The shaft may need replacement. It has an integral bearing.
Old Apr 6, 2010 | 09:16 PM
z28beast's Avatar
ok any part number on bearing? are you telling me the shaft should not wobble at all?...shoebox i thank you for all your help...your a guru on the lt1 bro
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
