water pump drive plug help
Old Mar 27, 2006 | 08:14 PM
pat35's Avatar
just got my summit electric water pump and double roller chain, what did you guys use to block the hole in the timing cover for the water pump drive? I got a freeze plug size1 1/4 that is pretty thin,but looks a little big. what did you find to install and location you found it?
Thanks!
Pat
Old Mar 27, 2006 | 09:28 PM
pat35's Avatar
Re: water pump drive plug help
aany one
Old Mar 27, 2006 | 10:10 PM
3gc's Avatar
3gc
When I installed the ewp i just took the coupler off and left the thing sticking out of the timing cover. I didn't think it was worth removing the timing cover to plug it when it didn't hurt anything with it still there. But when I put my 383 in i got a freeze plug that fit best and JB welded it into place.
Old Mar 27, 2006 | 10:23 PM
SnakeOiler's Avatar
Originally Posted by 3gc
... i got a freeze plug that fit best and JB welded it into place.
That's what I did as well.
Old Mar 28, 2006 | 06:03 AM
pat35's Avatar
do you know wat sise.
Old Mar 28, 2006 | 11:53 AM
pat35's Avatar
ane one
Old Mar 28, 2006 | 11:57 AM
SentimentalValue's Avatar
Try this out:
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Old Mar 28, 2006 | 12:10 PM
LT4orbust's Avatar
1 1/8"
Old Mar 28, 2006 | 01:04 PM
pat35's Avatar
i am tocking about the timing case cover hole . i tried 1 1/4 is a little to big and 30 m to smal.l this is all i coud find . in parts stors
Old Mar 28, 2006 | 01:22 PM
Javier97Z28's Avatar
Moderator
a quarter and some quick steel will do the trick.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
