water pump drive plug help
just got my summit electric water pump and double roller chain, what did you guys use to block the hole in the timing cover for the water pump drive? I got a freeze plug size1 1/4 that is pretty thin,but looks a little big. what did you find to install and location you found it?
Thanks!
Pat
Thanks!
Pat
Re: water pump drive plug help
When I installed the ewp i just took the coupler off and left the thing sticking out of the timing cover. I didn't think it was worth removing the timing cover to plug it when it didn't hurt anything with it still there. But when I put my 383 in i got a freeze plug that fit best and JB welded it into place.
