Water Pump????
Old Mar 13, 2007 | 05:09 PM
CamaroSS8887's Avatar
Water Pump????
about a month ago my car temp would spike then in a materr of 10 -30 seconds it would go right back down to 180... When it would spike the heat wouldn't work.So im guessing there is no water getting to the block....Now yesterday the temp guage wont work at all, the heat won't work and the two bleed valves nothing comes out of them..The thermostat was replaced last week and no fix.
Now is it the water pump not working.... ANd if i have to get a new one should i get electric or mech.. The car is rarely driven when im at school.only drive it during the summer.
Old Mar 13, 2007 | 08:19 PM
MyWifesZ28's Avatar
Squeeze upper radiator hose for pressure with car running.
A spike in the temp, no heat...Check the radiator level with the car running, start out cold with cap removed, if it's full and you said the cars sits, I'm thinking blockage.
It honestly sounds like coolant level is not propoerly serviced
Old Mar 13, 2007 | 11:45 PM
I have squeezed the line and there is no preasure in it... I have bleed and filled the radiator up multiple times..
Old Mar 13, 2007 | 11:57 PM
JP95ZM6's Avatar
If it bled and full, and only overheats briefly then the temp comes back down, it sounds like coolant flow is stopping intermittently. Mine did that at first, when the pump driveshaft splines were stripped. Mostly at high rpms.
You can pull the cover off the front of the pump and try to rotate the impeller to check. It shouldn't turn. Drain the coolant first, of course.
I think exhaust leaking into the coolant passages could cause the same kind of thing.
Old Mar 14, 2007 | 02:40 PM
2000GTP's Avatar
Maybe check to see if there is any air pockets in the system.
Old Mar 14, 2007 | 03:28 PM
transAMdriv3r's Avatar
what he said ^
mine was throwing me a fit yesterday when I went down town. I had both fans on (manual fan switch) and when I sat at a traffic light the temp would spike near the red, then once I the rpms went up, the temp would go back down. turns out there was alot of air in the system.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
