water leaking
Old Mar 24, 2004 | 06:31 PM
MeanZ687's Avatar
water leaking
i have recently had a water puddle form underneath my drivers side backseat when ever i am driving in rain. does anybody know what the problem could be or where the water would be leaking in
Old Mar 24, 2004 | 11:08 PM
RENE95Z's Avatar
Do you have T-Tops? If so, start there and check all seals. If not, my guess would be the hatch is not sealing properly.
Old Mar 25, 2004 | 03:05 PM
MeanZ687's Avatar
Unhappy
no ttops and the puddle only forms under the drivers back seat when i am driving in the rain
Old Mar 25, 2004 | 05:10 PM
SlickBlack Z's Avatar
I had this same problem about 5 years ago. The car was still under warranty at the time, so the dealer fixed it. If I remember correctly, it had something to do with the doorseal being defective. Must be a semi-common problem. What year is your car?
Old Mar 25, 2004 | 08:03 PM
Ryan94transam's Avatar
If the water is where the backseat passenger's feet sit, you are probably missing the rubber plug in the floor right there. If you look under your car in that area, you should see a round rubber plug in the floor pan there, and on the passenger side too. If it is missing, you can see your carpet padding kind of sticking out the hole. Splashing water gets soaked up in the pad and soaks the carpet there. Still missing my passenger side plug.
Old Mar 25, 2004 | 08:50 PM
MeanZ687's Avatar
no its a puddle underneth the drivers back seat no where ur feet go but under it.
Old Mar 25, 2004 | 08:57 PM
1BadBird's Avatar
Had the same problem. Most likely coming from your hatch. To be sure your gonna have to take out your rear drivers side seat then the rear panel where your speakers are mounted in your hatch area, then with your hatch closed take a hose and spray it where the hatch meets the rear quarter panel. 9 times outta 10 you'll see the water come in and run down the hump in your passenger compartment and form a pool of water in the area where the rear seat is. If this is what you see then all you need to do is buy some weatherstrip sealer and reseal the weatherstipping where it curves (if you see the stream of water you"ll now where to reseal) my suggestion is to do about a 6-12 inch area in either direction of the leak to make sure its sealed. This seems to be pretty common. I fixed mine about 2 years ago and not a drop since. Good luck.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
madwolf
Aug 2, 2001 08:32 AM
