"Warranty Void If Removed" label on heads
It's heads for LT1. Label on the penny size discs attached to heads. No other visible labels. Spark plugs seems to be on slightly different angles, then stock (relative to header primaries). What heads these can be??? I'll try to make some pics.
Re: "Warranty Void If Removed" label on heads
Sounds like a heat tab. They are used by junk yards, engine shops and reman companys for the warrenty. If the heat tab is gone or melted they know that you overheated the motor and voided the warrenty.
Magenta_Hearts
Mar 25, 2015 10:24 AM
