want to switch to afr heads? stroker
Old Feb 4, 2005 | 07:54 PM
Mystic97Z's Avatar
building a 383 or 396 stroker...have le1 heads. those will restrict my potential right? what afr head to i need to get? i still want to use my stock lt1 intake manifold. what are the different series afr head, and what would work for me,,,my le1 heads peak around 271-274 on the intake side. and where can i get them and for how much$ ? i don't know alot about afr's products...or should i just stick with my le1 heads? money IS a concern also.
thanks
also, whatever i get, i do not want to have ported...so if its better i'll just stay with le1's....
-Jason
Old Feb 4, 2005 | 08:49 PM
jchevy's Avatar
Re: want to switch to afr heads? stroker
If you sell your LE1 heads and cam i would be very interested. I just emailed LE about this today. Please shoot me a PM if you do so.
Old Feb 4, 2005 | 10:44 PM
1racerdude's Avatar
Those heads are capable of 550FWHP everything else being correct. It will take a very large cam and a intake system to flow with the heads. AFR 227 fully ported by a good head man not AFR, will make 650+ everything else being correct.
Old Feb 5, 2005 | 12:39 AM
ajschult's Avatar
If you are going to want to see a large gain over what you have, I would say that you're going to need to go a full port lt1 or an lt4 setup. Not sure what the 195s put down, but I would say its probably not gonna be worth the money. my .02
Old Feb 5, 2005 | 04:16 AM
n2oblkz
Guest
Posts: n/a
Yeah, unless you are wanting to step up and get the AFR 210's, 220's or 227's and use a LT4 intake, I don't think that it is worth the cash. A lot of people have VERY good results with ported stock heads. A good friend of mine has a 94 Z with a solid roller 396 LT1 that uses ported stock casting heads and LT1 intake to run 10.80s on motor. They are better than what you think. I think it just depends on how much extra money you want to spend.
Old Feb 5, 2005 | 04:57 PM
med_reject's Avatar
I have never seen or heard of le1 heads producing 550fwhp or afrs producing 650+, unless you're thinking solid roller cams with 280ish duration. To get those heads to flow that much air is impossible on even the most aggressive streetable combinations.
Highlander
Jan 12, 2020 02:13 PM
RUENUF
Mar 13, 2016 03:39 PM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
