Want to see what 176k looks like on the LT1?
Old Feb 4, 2008 | 10:06 PM
  #16
KyleBlue85Iroc-Z's Avatar
Originally Posted by T/A KID
About to pull my motor and tranny from the bottom with my lift. I have a really good idea on doing so but any tips or steps??????
I didn't know exactly how to get all the wires away from the body at first. It took a little bit of looking to realize I had to unplug like 4 connectors behind the passenger, side foot well and pull the whole harness out into the engine compartment. Also didn't realize how much of a PITA the power steering lines are!
Old Feb 6, 2008 | 10:09 AM
  #17
IrocSS85's Avatar
see how the struts are tied IN towards each other? if you dont do that, when you lift the body they will fall outward and pull on the brake hoses. you could also take out the 1 bolt per side and pull the steel line out a couple inch's to give plenty of slack to let the struts hang outwards. dont forget to unhook the wheel speed sensor connectors and take away the connector thats got a retainer holding it to the painted body instead of the kmember.
as for the brake lines, you gotta take them out of the abs motorpack. the two that will stay as part of the kmember. you'll have to pay attention to how there routed as your lifting the car off the kmember/engine cause they kinda intertwine.
also take special note of how the power steering lines/hoses are routed compared to the a/c lines on the pass side between the fans and the accesories.
Old Feb 6, 2008 | 02:02 PM
  #18
neil350's Avatar
Looks good Kyle, be a great time to give that engine bay a good cleaning. Glad to see you kept the car!
Neil
Old Feb 6, 2008 | 02:21 PM
  #19
reamo04's Avatar
definately would be a good time to clean up wires, and if youve been wanting to, delete AC, stuff like that
Old Feb 6, 2008 | 04:52 PM
  #20
One other thing, I didn't realize how easy it was to just pull out the ABS module and master cylinder together. Doing that made life quite a bit easier.
Also, how hard is it to change the slave cylinder and where is the best place to get one? Mine appears to be almost shot.
Old Feb 7, 2008 | 07:45 PM
  #21
white97T/A's Avatar
Here is one for sale for $75, maybe worth looking into.
http://www.ltxshootout.com/forums/sh...?p=769#post769
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
