Walbro fuel pump install, and fuel pressure problems?
Old Jun 8, 2010 | 05:48 PM
RACEON's Avatar
Just curious if anyone has had there car run richer/leaner, more pressure etc after Walbro GSS340 was installed?
Old Jun 9, 2010 | 12:02 AM
RamAir95TA's Avatar
Shouldn't matter whatsoever. Fuel pressure is controlled by the FP regulator, not the fuel pump.
Old Jun 9, 2010 | 09:19 AM
RACEON's Avatar
Thats what I figured. The pump is working. I installed two things at once, injectors and pump. I retuned for injectors and its not running too well. I sent the injectors off to get flowed, cleaned etc etc. I was trying to eliminate possibilities with the pump. Injectors sat on a shelf for over a year, and I didnt clean them other than with injector cleaner in a bucket and spray.
Old Jun 9, 2010 | 05:43 PM
Have you checked the fuel pressure?
Old Jun 9, 2010 | 07:18 PM
RACEON's Avatar
43.5 psi with vacuum off. Fluctuates a little as the fuel damper installed on Vettes isnt there as Racetronix tells you to install rubber hose in place of it.
http://shop.corvettecentral.com/1985...-p6021542.html
Gtpguy
Jan 26, 2015 04:50 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Skull Leader
Aug 10, 2002 11:01 AM
