VRE 396ci Short Block
Old Mar 29, 2010 | 01:54 PM
Crafty's Avatar
I was wondering if this package is worth the money, or should I try to buy all the parts to make my own.
Description:
Victory Racing Engines 396ci LT1 engine rounds out our LT1 line-up. It is the largest LT1 engine we produce. Whether you are looking for a street/strip package or looking for an all out race combo, the VRE 396 LT1 is the pinnacle of LT1 Performance.
Specs:
Compstar 3.875" Stroke 4340 Crankshaft
Compstar 6.000" H-Beam Rods
SRP -5cc Flat Top Pistons
Mahle Rings
Clevite Rod Bearings
Clevite Main Bearings
Clevite Cam Bearings
ARP Main Studs
Balance Rotating Assembly
Fully Machine Block w/ Deck Plates
Blueprint and Assemble
Options:
Fel-Pro Head Gaskets $39.99ea
Cloyes Timing Set $90.99
Comp Cams Camshaft $245.99
BBK 58mm Throttle Body $309.99
Piston Coating on Skirts and Tops $315
ATI Harmonic Balancer $379.99
ARP Head Studs $124.99
Upgrade to Callies Dragonslayer Crankshaft $500
Upgrade to Diamnd Pistons and Rings $250.00
Price:
$3700.00 *No Block Core Requirred*
Old Mar 29, 2010 | 02:41 PM
Crafty's Avatar
Also will my stock lt1 parts fit on that block. I.E. intake manfoild and heads.
Old Mar 29, 2010 | 03:30 PM
97FormulaWS-6's Avatar
It's a really good combo for the price; and stock parts will fit; but an upgrade to the heads/cam department is HIGHLY suggested.
Old Mar 29, 2010 | 03:40 PM
neil350's Avatar
Parts are fairly priced, machine shops make money on machine work/labor, they don't make a ton on the retail end of parts. I can't see doing a 396 and leaving the stock heads on. Save money and do a 355 with heads and cam.
Old Mar 29, 2010 | 03:59 PM
Crafty's Avatar
Thanks, ill keep looking around
Old Mar 29, 2010 | 04:39 PM
bombebomb's Avatar
I think it would be good to know what exactly he plans on doing before shooting off ideas like "Save money and do a 355 with heads and cam.".
If you plan on doing heads later, I recommend doing the 396 now. That way you are not building it twice.
If you never plan to do heads on the 396, do a 355 h/c.
Old Mar 29, 2010 | 11:35 PM
Crafty's Avatar
Ya, I was planing on buying heads, cam, and intake down the road when I get more cash flow
Old Mar 30, 2010 | 10:47 AM
97WS6SCharged's Avatar
You may want to work with Eric and see if he can cut you a deal on a turn key setup. It's more $$ up front but less in the long run.
Old Mar 30, 2010 | 01:29 PM
bombebomb's Avatar
I say go 396 then, that way its ready for the future. Obviously it will not run top notch at first but you will be able to drive it fine.
Old Mar 30, 2010 | 02:57 PM
Crafty's Avatar
Any tips on the other parts ill need down the road, I.E. not stock heads and cam lol
Old Mar 30, 2010 | 09:25 PM
slomarao's Avatar
well whats done to you car as of now?
If your stock you could get the bolt ons done. That way when you do build a motor all you will be paying for is the build.
Long tube headers, exhaust.
Cold air intake, pcm tune.
Gears, 1.6 roller rockers.
No matter what type of build you do down the road you will re use all 6 of those parts listed.
You should also do subframe connectors and a pcm tune.
Old Mar 30, 2010 | 10:41 PM
Crafty's Avatar
I have a stock 93' z28 with a cai, but my oil pump went out and shot a rod. That is why I was planing on buying a short block. I was wondering on like what cam and other parts to finsh the short block that I should buy.
Old Mar 30, 2010 | 11:24 PM
LT1PoloGreenSS's Avatar
dont put any money into the 93, buy a C5 Z06
Old Mar 31, 2010 | 01:18 PM
Crafty's Avatar
don't have the money for a c5 z06
MadMav
Jun 8, 2015 11:38 PM
R@mpage
Apr 20, 2015 10:02 AM
pimpss96
Feb 12, 2015 01:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
