vortech & trick flow elbow question
Old Feb 4, 2004 | 12:06 AM
SiDeWaYZz28's Avatar
Question vortech & trick flow elbow question
hey everybody does the vortech elbow have a hole for the sensor??does the trickflow have one?thanks alot
Old Feb 4, 2004 | 12:27 AM
Compstall's Avatar
I don't think they do. Just splice in some wire to the IAT sensor and tap a hole into the plastic in your intake tube.
Old Feb 4, 2004 | 12:32 AM
should i just drill a hole in the elbow
Old Feb 4, 2004 | 12:37 AM
96lt1Camaro's Avatar
vortech elbow DOES have a hole for the sensor. dont know about trick flow
Old Feb 4, 2004 | 06:41 AM
AxeGrinder30thZ's Avatar
The Trick Flow does not. You have to drill one. I forgot the size. They tell you in the instructions. They also supply you with a grommet to put in when you drill it. Go with the Trick Flow. Might require 2 minutes of more work, but I think it looks better.
Old Feb 4, 2004 | 07:13 AM
Derrick Redd's Avatar
My Trickflow elbow came predrilled with a hole. I just had to put the sensor in with the supplied piece.
Old Feb 4, 2004 | 09:47 AM
fastcamz28's Avatar
I've had both (Trick Flow on now) and they both come w/ the IAT sensor hole. Trick Flow even has a grommet to ensure a snug fit. Hope this helps!
Old Feb 4, 2004 | 10:14 AM
Don't Look Back's Avatar
Yep, fortunately the Trick FLow has a hole for the IAT. Only thing you have to do is drill a hole for the Opti vent if your year has it. Gromets included for both holes.
Old Feb 4, 2004 | 01:44 PM
IDOXLR8's Avatar
Ditto
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
