Voltage While driving?
Noticed lately that while cruising my voltage is right around 13. Shouldn't it be more at 14.4 or so? Also noticed that when i give it a good amount of gas the voltage sometimes dips down to 12 or so. Is my alternator going?
To some extent, it depends where you are getting your reading from. If you are running scan software, the voltage will generally show around 13.0 +/-. If you are looking at the dash volt meter, it will usually be higher than that.
My guess is you got a diode going out. I found out on mine by feedback through the radio, I can hear the alternator feedback now which I never heard before, my dad says when alternators start going they make all kinds of electrical noise.
Mine does something similar....At idle with no electrical load its straight up. If I turn on the a/c it dips way down to the middle of the red, but if I'm driving with no a/c on and it starts dipping, I just turn on the headlights and it brings it up a few volts.
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
Have your battery load tested.....
