Voltage While driving?
Old Apr 28, 2009 | 05:42 PM
MTBSully's Avatar
Noticed lately that while cruising my voltage is right around 13. Shouldn't it be more at 14.4 or so? Also noticed that when i give it a good amount of gas the voltage sometimes dips down to 12 or so. Is my alternator going?
Old Apr 28, 2009 | 08:02 PM
slp223's Avatar
your battery should make 12.4 and you alt should make 14.4. if it is dipping below 12 there is a problem.
Old Apr 28, 2009 | 08:34 PM
n2ceptor's Avatar
Also check for belt slipping.. Have your battery load tested.....
Old Apr 28, 2009 | 11:30 PM
MTBSully's Avatar
hmmm, will check tomorrow. anyone else?
Old Apr 28, 2009 | 11:41 PM
MikeGyver's Avatar
My ell tee won is like 12.8v while driving.
Old Apr 29, 2009 | 05:13 AM
To some extent, it depends where you are getting your reading from. If you are running scan software, the voltage will generally show around 13.0 +/-. If you are looking at the dash volt meter, it will usually be higher than that.
Old Apr 29, 2009 | 08:47 AM
derrickgott007's Avatar
Mine does something similar....At idle with no electrical load its straight up. If I turn on the a/c it dips way down to the middle of the red, but if I'm driving with no a/c on and it starts dipping, I just turn on the headlights and it brings it up a few volts.
My guess is you got a diode going out. I found out on mine by feedback through the radio, I can hear the alternator feedback now which I never heard before, my dad says when alternators start going they make all kinds of electrical noise.
Old Apr 29, 2009 | 09:12 AM
MTBSully's Avatar
maybe this would explain why whenever i use my ipod hookup i get a "whining" through the speakers that is consistent with engine rpms. hmmm
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
