voltage drop under acceleration
Old Feb 27, 2006 | 09:07 PM
Bandit95LT1's Avatar
I have done everything i can think of changed altornaters changed batteries( bought a optima)changed coil and plug wires, look for grounds and found some but i still loose voltage some how. it will be fine when i starte the motor up when the car is coldit will read bout 13.3 to 13.4 at idle and weill go don to bout 12.6 to 12.9 and evan farther down when i get higher up in the rpm range i have know clew what to do
Old Feb 27, 2006 | 10:52 PM
Z95m6's Avatar
Re: voltage drop under acceleration
I'd suggest a new fuel pump and pump harness from racetronix especially if you have an older car. Also a new ignition switch can really help alot also.
Old Feb 28, 2006 | 12:44 AM
1racerdude's Avatar
Belt slipping,loose connection,bad diode in alternator.
MDZ28
Sep 7, 2015 09:16 PM
Aug 7, 2015 01:26 PM
Aug 7, 2015 08:52 AM
Boss002
Jul 24, 2015 10:47 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
