Voltage drop after AC delete
Old Jun 22, 2004 | 11:34 AM
IDOXLR8's Avatar
I noticed after deleting my AC my computer is now reading 12.7 volts at idle. The weird thing is that I checked that alternator while the car was running and it read 14.3V at idle. I understand there is going to be some voltage drop to the computer but 1.6 V is alot. In the past I was reading 13.2 V at the computer. Could this be due to the accessory belt being too long and belt slippage occuring? I know some people have gone with an 1/2 inch shorter belt when deleting the AC. Any recommendations or advice would be greatly appreciated.
Old Jun 22, 2004 | 12:51 PM
sabre81's Avatar
my stock belt worked perfect. No change at all. Maybe your tensioner is not providing the tension it should?
Old Jun 22, 2004 | 01:21 PM
MEAN LT1's Avatar
Re: Voltage drop after AC delete
That is alot of voltage to lose but when my car was running thats was datamaster was reading as well when I had everything hooked up. I dot think its going to hurt you at all but if you start seeing less than that i would get concerned especially if the voltage gage goes in the red.
Old Jun 22, 2004 | 01:24 PM
IDOXLR8's Avatar
Re: Re: Voltage drop after AC delete
It has not gone into the red but has come pretty close.
Old Jun 23, 2004 | 05:58 AM
IDOXLR8's Avatar
Any ideas?
Old Jun 23, 2004 | 09:45 AM
sabre81's Avatar
did you check belt tension? alignment? a misaligned belt can affect power transfer. Maybe the belt if off a track. As for belt tension, it should deflect about 1/4 of an inch with tension on it.
Old Jun 23, 2004 | 09:48 AM
IDOXLR8's Avatar
The alignment is right on. The belt defintely has more than 1/4 deflection. I would say it is more like an 3/4 of an inch. Thanks for the advice.
KYWes
Jun 14, 2022 06:52 AM
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
big_mac421
Jul 13, 2015 03:48 PM
Boss002
Jul 9, 2015 03:33 PM
