Voltage to data port?
Old Dec 26, 2008 | 03:12 PM
MTBSully's Avatar
Anyone have the voltage values that you are supposed to get to each of the pins at the aldl port? With the ignition off, i got nothing except for 12V to pin #16. When i turned the key "ON", i got 5V to pins 6 and 9 in addition to the 12V to pin 16. Does this seem correct?
Courtesy of shoebox
Old Dec 26, 2008 | 03:41 PM
It is correct, even though you may be looking at an OBD-II DLC.
Old Dec 26, 2008 | 06:42 PM
MTBSully's Avatar
so the voltages are correct? what does DLC mean Im trying to figure out why i cant get any power to my scanner
Old Dec 26, 2008 | 10:55 PM
It says right there in the pic above "Data Link Connector".
4 and 5 should be grounds and you would probably see 5v on 2 (again assuming it is an OBD-II DLC-you never confirmed).
Old Dec 27, 2008 | 12:09 PM
MTBSully's Avatar
its a 97, so it has the OBD-II style 16 pin connector. However, the car does have an obd1 computer with obd1 tuning
Old Dec 27, 2008 | 02:07 PM
What kind of scanner are you tying to use? When you switched to the OBD-I PCM, did you do anything to the DLC?
Old Dec 27, 2008 | 03:24 PM
MTBSully's Avatar
trying to use otc scanner. is the dlc the same as the aldl connector port under the steering wheel? I did not do the obd-1 switch so i have no idea
Old Dec 27, 2008 | 04:02 PM
If wired properly pins 5 and 9 are the only ones you need to scan OBD-I.
http://shbox.com/1/1995_pcm1.jpg
Old Dec 27, 2008 | 08:40 PM
Not the brand... is it an OBD-I capable scanner?
Yes.... ALDL = DLC. There is a picture of one above, and you asked what the "DLC" was, so I thought that would be very clear.
RUENUF
Mar 13, 2016 03:37 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
Aug 7, 2015 01:26 PM
13qtr
Jul 19, 2015 05:30 PM
