Volt gauge on dash....
Old May 8, 2003 | 08:00 PM
96z's Avatar
96z
Mine is nearing the red checkered zone....is this the alternator or the battery....both were already checked a couple weeks ago....
Old May 8, 2003 | 08:06 PM
96z's Avatar
96z
Slightly....it comes right back though...
Old May 8, 2003 | 10:16 PM
96z's Avatar
96z
Anyone else?
Old May 9, 2003 | 03:11 AM
Terran2k's Avatar
maybe the guage on your dash is reading wrong?? put a DMM across the batt and see what the alternator is putting to it and if it matches what is on the guage?
Old May 9, 2003 | 09:33 AM
96z's Avatar
96z
Ok Ill test it than, is there a way to tell which is bad just looking at the guage?
Old May 9, 2003 | 09:38 AM
You should get 12v or so with engine off. When running, it should be over 13v.
Old May 9, 2003 | 10:56 AM
anasazi's Avatar
the guage on the dash isn't worth anything...
mine when checked with a proper tool will sometimes show 12v and the thing is way up past the middle, and it can also show 12v and its sitting there right on the edge of red. i've also had it be over 13v and be sitting at red... its almost worthless.
Old May 9, 2003 | 11:56 AM
Mine is fairly accurate.
Old May 9, 2003 | 01:13 PM
kgkern01's Avatar
Mine is pretty accurate also, I had it checked, my alternator isn't putting out the volts it needs to, only about 11-12 instead of 13-14
Formula Steve
Sep 19, 2023 08:31 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
