videos of the ss with the fms cam installed
after having the cam sitting here for months i decided to put it in.
the cam is a 233/241 on a 112, the exhaust is slp midlenghts, h-pipe and true duals into bullet mufflers.
the first one with the hood closed was with zero tuning and it was sorta loading up from the 37 lbs injectors running on the 24 lbs injectors tune.
http://www.mofbody.com/blkchevyz/briancam.mov
the second is after some tuning for the injectors and some timing in the lower rpms. it cleaned the idle up quite a bit.
http://www.mofbody.com/blkchevyz/briancam2.mov
notice the blower like whistle
Re: videos of the ss with the fms cam installed
Originally Posted by hawk232
sounds like mine, i wonder why
i think that makes 3 of us that i can find on here with that cam, how do you like it?
mine for some reason loved more fuel, i think i made peak power with a final a/f of about 12.7:1 kinda weird but power is power. where are you shifting at? i shift ~6800 of course im just guessing with the stock tach lol
right now i havent bumped up the accel box so the limiter is around 6300 and the shift light is still set around 5800. i have yet to get it on a dyno to see what it wants becouse we still have more tuning to do. we still have to add more fuel but like you said, the more we added the harder it pulled.
i can tell you that 5800-6000 its still pulling like a freight train
mines almost the same, i got a little more duration and lift but not much.
im wanting to say that it peaked around 6300, but it doesnt start falling off till about 6500. i know one time i dropped from 6800 to like 6300 and lost 3.5 mph
needless to say the shift points were back at 6800. mine is also cam only, i dont know about all of yours...
Originally Posted by JoeliusZ28
like the plate frame
sounds bad man
sounds bad man
numbers and times coming really soon. hopefully in a week or so ill have some numbers from the dyno. i have a few more things to do this winter and im in the middle of cutting up and intake to see if i can inptove it.
NewsBot
Jan 29, 2015 07:10 PM
F(ast)-body
Feb 26, 2003 09:05 AM
