Video of my car: Open LT's heads/cam(GM 847) first startup. 56K beware
Old May 3, 2005 | 09:13 AM
  #16
Kurt Crosbie's Avatar
Re: Video of my car: Open LT's heads/cam(GM 847) first startup. 56K beware
oh ok, it worked. forget about it.
Old May 3, 2005 | 11:51 AM
  #17
'94 Bad A Z28's Avatar
There you go guys, everyone who wants to see it better get it while they can, because another board member has the video hosted for me.
Old May 3, 2005 | 10:45 PM
  #18
Would you mind putting up a video or sound clip of the car after its warmed up so we can hear it idle down low?
Old May 3, 2005 | 11:41 PM
  #19
As soon as the car is up and running again, and tuned, I will post up another video. I didn't take any other video of the car before the oil pump died on me.
Old May 4, 2005 | 04:43 AM
  #20
dang, oil pump took a crap on you? how did you catch it before it tore the motor up?
Old May 4, 2005 | 11:23 AM
  #21
I was on my way home about a mile and a half from my house and I made a hard right hand turn and it looked like my oil pressure droped to nothing for an instant. So rolling at about 20mph I descided to stab the gas and watch my oil pressure. Oil pressure shot up to about 45-50psi right away. Stayed there for a second and dropped to 20psi. Got out of the gas and the pressure dropped to 0, gave it a little gas to keep the car moving about 1500rpm and it brought the oil pressure to about 8-10psi, was right down the road from my house so I limped it home like that.
Replaced the oil pump, started the car and it was fine. Good oil pressure no knocking. Drove it for a little bit and there was a small clicking noise. Me being the way I am would rather something go wrong at this point rather than out racing (at the track... or whatever) so I pulled off to a side street and come to a complete stop and floor it. The car blew the tires off like it should, for a second, and then seemed to loose a little power, and then clicing and clanging. Turnes out that the little bit of lost pressure lead to me needing rod bearings and a new crank.
I've got a new motor I'm just too lasy to switch my heads/cam over to it and do a motor swap, hah.
Old May 4, 2005 | 02:19 PM
  #22
fredmr39's Avatar
Originally Posted by lamb110
that sounds awsome man
i bet the neighbors were happy with the tests at 3:30...
ha...reminds me of when i finally finished header install at 5:30am over winter break...family was alsspe, siblings had to get up in under 2 hours for school, and I tried to convice them to come down.....didn't work though...
Old May 8, 2005 | 11:58 AM
  #23
header install vs. heads/cam/headser install is a little different.
Old May 8, 2005 | 01:11 PM
  #24
chevy94c's Avatar
Thumbs up Re: Video of my car: Open LT's heads/cam(GM 847) first startup. 56K beware
Sounds nice
Old May 8, 2005 | 02:30 PM
  #25
Kain's Avatar
DL works for me.
Old May 9, 2005 | 05:40 AM
  #26
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
akwa
Apr 5, 2015 05:09 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
