VIDEO: LT1 Problems turning engine over and starting
Old Dec 5, 2008 | 09:16 AM
  #31
SS RRR's Avatar
Originally Posted by bz7
I primed it by pulling the injector fuses and letting it crank for a few seconds before starting. Any other suggestions?
If the engine can barely turn over then how was it able to prime?
Old Dec 5, 2008 | 01:55 PM
  #32
bz7's Avatar
bz7
The engine is able to turn over smoothly now. I put some oil into the cylinders to loosen things up and hooked up a new Optima. Before I was using jumper cables hooked up to the starter and engine block and to a running car, but this wasn't providing enough power.
I'm trying to get a oscilloscope tonite to see if VATS is the problem.
Old Dec 6, 2008 | 11:26 AM
  #33
94Firehawk161's Avatar
Has the VATS been disabled in this PCM, or is it still enabled? Are you using all of the VATS components and are trying to retain the VATS system?
Old Dec 6, 2008 | 07:55 PM
  #34
bz7's Avatar
bz7
VATS is still enabled, I'm using all of the VATS components and a resistor which matches the key soldered into the VATS module wiring.
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Injuneer
Dec 15, 2014 09:36 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Jul 4, 2005 05:00 PM
