Video: Heads/Cam idle/rev
Old Jul 23, 2006 | 11:17 PM
  #16
HardcoreRM125's Avatar
Re: Video: Heads/Cam idle/rev
You need to dyno it ... and for sure do one with the cut out closed vs open.
Nice video.
Old Jul 24, 2006 | 01:11 PM
  #17
'94 Bad A Z28's Avatar
Nice video.
Deffinately do that whenever I get a trans back in the car.
Old Jul 24, 2006 | 05:43 PM
  #18
marshall93z's Avatar
What, the cutout closed video?
Old Jul 26, 2006 | 01:58 PM
  #19
I already posted one of those.
Old Jul 26, 2006 | 05:34 PM
  #20
Your first post says it is with an open cutout.
Old Jul 26, 2006 | 10:33 PM
  #21
I just wanted a video of it with it closed this time.
And wanted, to show a great comparison, how much the cut out helps in horsepower/torque. So a dyno run with it closed, vs open.
Although, I think this is somewhat biased when compared to a regular exhaust. When the cut out is installed, but closed, it creates a huge turbulance, which, when its closed, will cause it to make slightly less power than it would have prior to the install. Well, depending on the location of it I guess. Tuning the length of the exhaust for the right RPM range can make a noticable difference in power.
Awesome video. Sweet car. Keep us updated and good job with it.
Old Jul 26, 2006 | 11:29 PM
  #22
97WS6SCharged's Avatar
Sounds similar to mine. You should pull off the cover though.
Old Jul 27, 2006 | 01:47 AM
  #23
Yes, this video is open cut-out, search for posts by me and you will find another video with this setup and a closed cut-out.
Old Jul 27, 2006 | 01:53 AM
  #24
I know what you are talking about, and I will video it whenever it get's on the dyno, and have a comparison open vs. closed. The little bit of turbulance doesn't affect it all that much, I did open vs. closed dyno pulls before the heads/cam and everything, all I saw (if I remember correctly) was a 7rwhp difference.
Thanks for the props, and as soon as I get money saved up for another trans, and get it in the car, I will get the car to a dyno with video footage.
Old Jul 27, 2006 | 01:57 AM
  #25
Bleh... not much to see...
Old Jul 27, 2006 | 02:06 AM
  #26
Oh yeah, the car has "projectors" now that I will be changing to HID projectors shortly after the car gets a trans.
Old Jul 27, 2006 | 07:13 AM
  #27
Sweetred95ta's Avatar
I'd keep it covered too if all of that construction was going on around me. Car sounds good.
Old Jul 27, 2006 | 09:14 AM
  #28
Those were pictures I took when I took my car to a job site one day, no construction around me.
Old Jul 27, 2006 | 01:20 PM
  #29
AZ2ENVY's Avatar
What lowering kit did you use ?
Old Jul 27, 2006 | 02:21 PM
  #30
Mr_Bond's Avatar
sounds good
