vibrations : engine related or not ?
Old Feb 11, 2009 | 06:39 PM
Sporty-X's Avatar
Hi,
i've recently converted my car from A4 to M6. since then, the car not anymore what can be called "streetable" under the 2200 rpm line with very bad "vibrations" that you can feel strongly with the shifter shaking in the car.
My problem is : i dont really know if this problem has happen since the conversion or it is engine related and the auto + converter helped not to feel it before.
My setup is :
stock shortblock
LE2 heads + LE1.5 cam
LT / 52 holley / 30 SVO
since i've my M6, i've used :
* stock new M6
* Mc Leod 7500 clutch
* RAM flywheel
just in case , it is not engine related , i've different questions :
1) can the RAM aluminum flywheel too light for this setup and be the cause ?
2) i've seen posts about special position to bolt the pressure plate to the flywheel. I have just bolt it without having look if there was any. can it be the pb ?
3) i've seen people talking about pressure plate bolts. I didn't have the stock ones so use some aftermarkets bolts that have threads on their whole lengh. maybe it can has caused a misalignment ?
Any idea would be appreciate. if engine related also what to check ? (would be great before having to take the trans out) MAF ?
Thanks for help.
Pierre
Old Feb 11, 2009 | 07:32 PM
Acct 23749's Avatar
1. did you put in a pilot bearing in the back of the crank?
2. The flywheel on an LT1 needs to be balanced.... i dont know if you after market one is or not
Old Feb 11, 2009 | 07:53 PM
Sporty-X's Avatar
yes i've put a pilot bearing
the flywheel has been balanced same as the auto flexplate
Old Feb 11, 2009 | 08:01 PM
jtarp's Avatar
I don't believe the flywheel being to light would be the problem. Do you have the T56 crossmember and all the other mounts tightened completely?
Old Feb 11, 2009 | 08:58 PM
Sporty-X's Avatar
hello jtarp : yes T56 crossmember everything is tight well.
i forgot : when i did the conversion, i didn't had the right mount for the torque arm (though it would be same), so we made one by ourself to have the torque arm on the gear box. can it be a problem too ?
Old Feb 11, 2009 | 09:36 PM
Acct 23749's Avatar
two more thoughts
1. you sure on the quality of the tranny? maybe its bent imput shaft of something the previous owner didnt tell you
2. the tq arm mount should be fine, i just did the identical thing yesterday with mine. I accidentally got an auto tq arm mount from my t56... had to cut cut, bend grind and drill it to work, but its does.
Old Feb 11, 2009 | 10:12 PM
Sporty-X's Avatar
the tranny was new from the shop . never had any oil in it.
thanks for the info for the mount. one thing less to worry
Old Feb 12, 2009 | 11:07 AM
multicar's Avatar
I thought pressure plate bolts were shoulder bolts used to center the plate on the flywheel. I'd check the simplest things first...replace 'em with the correct ones.
Old Feb 13, 2009 | 12:34 AM
user 647483's Avatar
The LE1.5 cam should be plenty streetable and idle well at 950-1000 without any significant vibration
If you're sure that the flywheel was matched to the flexplate (you have a stock bottom end, I'm assuming?)
I'd check for loose bolts; specifically the flywheel.
Did you also switch to poly motor/trans mounts?
Are you running a base tune set up for that cam and those injectors?
Old Feb 13, 2009 | 02:07 AM
Sporty-X's Avatar
i've not changed to poly mounts. Still original ones.
I've also thinkong about that loose bolts.
i will take the tranny off when possible to check.
DirtyDaveW
Dec 1, 2016 05:37 PM
karnykamaro
Feb 2, 2015 01:37 PM
4586
Dec 31, 2014 02:21 PM
mattszm6
Dec 14, 2014 07:09 AM
squarehead
Nov 21, 2014 08:02 PM
