Vibration from center console at high speeds
Old Feb 10, 2004 | 10:30 AM
  #16
PlaneCrazy's Avatar
Good to know.. Thanks.. And dam.. I wanted to order the SLP loudmouth
Is this something I need to do like right now? Or just don't speed so much?!
Old Feb 10, 2004 | 10:41 AM
  #17
GP-1's Avatar
Well, I guess that would be your call.. I figured that a u-joint was gonna break at some bad time, so I wanted it done ASAP..
Old Feb 10, 2004 | 12:03 PM
  #18
jbird's Avatar
Yeah, switching a driveshaft isn't a big deal. It's about like changing oil, lol, maybe easier. You should also put in new u-joints. That will make your job a little more difficult, but it's well worth the effort. I busted a u-joint in an old ford pickup once w/a two piece driveshaft. The rear shaft fell out and got all bent up. I had to have a new one made. It was a pain. So, while you have it out anyway, you might as well do that.
It also could be a worn tranny mount, not quite busted, but worn. When you're on the throttle the engine is trying to push the tranny one direction, when you're off (engine braking) the tranny is trying to push the engine backward in essence, but really just exerting force in the opposite direction, which means the tranny is trying to turn a different way. (May just be my sleepy ramblings, lol, I didn't get in bed last night) Maybe someone else can confirm this. Anyways, when you're on the gas, the tranny is putting pressure on the mount one way, and when you're off the gas, the tranny is pushing the mount the other. Someone chime in and let me know if I'm right.
If I were you, I might try to change the tranny mount first because it is cheaper than a new shaft. You'll be p@ssed if you get a new shaft and the vibe is still there. Could this also be a u-joint going bad? Again, maybe someone else will chime in here.
Hope this helps. ---J.Bird
Old Feb 10, 2004 | 12:10 PM
  #19
ShiftyCapone's Avatar
Could going over bumps and just cruising cause this as well. I have a horrendous fast clunking coming from the center console at speeds above 40 while crusing. It will clunk for a minute at a time sometime at only 65mph. I will often hear it if a bump is big enough at slow speeds as well.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
mattstrike
Mar 11, 2015 07:33 PM
CaRParts102
Dec 6, 2014 08:45 AM
x7x7
Aug 15, 2002 06:49 PM
