Vibration from center console at high speeds
Anyone with the M6 have this prob? Above 85 (on the track
), when I let off the gas, the center console starts vibrating.. If I stay on the gas, it doesn't. If I push the clutch in at those speeds, same thing, or if I throw it in neutral..
Any ideas? Driveshaft outta whack? Not sure why it wouldn't vibrate under load though, and only when coasting..
Also, if I remember correctly, my 94 Formula A4 did the same thing..
Thanks for any help.
), when I let off the gas, the center console starts vibrating.. If I stay on the gas, it doesn't. If I push the clutch in at those speeds, same thing, or if I throw it in neutral.. Any ideas? Driveshaft outta whack? Not sure why it wouldn't vibrate under load though, and only when coasting..
Oh yeah? My tranny mount crapped the bed twice in my Formula, and the symptom was when I gave it hard throttle, it would go CLUNK CLUNK CLUNK
Then I got the Polyeurothane one, and it never broke again..
I can go WOT and it doesn't vibrate, just does it above 85mph..
Originally posted by transam41282
Do you have an energy suspension tranny mount? Those make things vibrate more.
Well then just climb under there and change out the tranny mount. Its like a $35 part. After that you should be good to go. Now if it starts to feel like your tranny fell out of the car when you hit the gas, then its definately the tranny mount. Either way, change and your issue should be resolved.
Originally posted by PlaneCrazy
I bought the car 6k miles ago, I put nothing on it.. I don't believe it has an ES mount..
i orderd poly mounts from thunder racing and got them quick for a good price......give them a try, theyre in the "supporting advertiser" list.
Originally posted by GP-1
Mine did the same thing... It was the driveshaft..
I guess I should see about getting a new balanaced DS.
