vertical radiator questions
Old Feb 10, 2010 | 07:52 AM
  #31
95mysticta's Avatar
Any leads to are the best fans to use with an aftermarket fan? Also whats the best way to mount it to the car?
Old Feb 10, 2010 | 04:44 PM
  #32
chevyrules85's Avatar
what he said ^ ?????
Old Feb 11, 2010 | 09:18 AM
  #33
mzgp5x's Avatar
I moved my rad forward (Summitracing - BeCool), and, installed (2) Flex-a-Lite 12" pull type fans. Low profile. I had to fab my own mount for fans and cut some of the housing/ shroud to make them fit. They are a permanent part of the rad for easy removal. F_body is all about easy assy/ dis_assembly. Fans work good, but, there are many options now that single big fans can be purchased (@ Summitracing.com).
B.
Old Dec 23, 2010 | 01:32 AM
  #34
stephenpen's Avatar
Re: vertical radiator questions
I now its an old post but what did you guys do about the steam pipe return hose ?
Old Dec 23, 2010 | 01:58 PM
  #35
theres an 1/8 inch NPT fitting in the top of the water outlet, i just put a 3/8 barb fitting in that location, and ran the hose to it, and no problems with it so far
still havent figured out what to do for fans yet....
Old Dec 23, 2010 | 10:32 PM
  #36
stephenpen's Avatar
Isn't there 2 more smaller hoses on the stock rad.
Magenta_Hearts
Mar 29, 2017 08:54 PM
grgguy
17
Feb 23, 2015 07:57 PM
rjc1629
Jan 27, 2015 10:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
