vertical radiator questions
Old Dec 29, 2009 | 11:10 AM
  #16
bw_hunter's Avatar
Originally Posted by 97WS6SCharged
Move to Florida and say that.
LOL..no kidding!
Old Dec 29, 2009 | 11:49 AM
  #17
chevyrules85's Avatar
haha we have plenty of hundred degree days here, more in the 90s but its still damn hot, dont know about the humidity tho, ive never been to florida. it justs sucks at stop lights not bad when your movin lol
Old Jan 6, 2010 | 11:43 AM
  #18
oh yeah, when i move the rad vertical, can i just use like an aluminum catch can from summit for the over flow instead of using the stock one? thanks guys!
Old Jan 12, 2010 | 12:26 AM
  #19
sam pace's Avatar
Ok, I will.....lol Its not that bad Thats why they made t-tops
Old Jan 12, 2010 | 10:25 AM
  #20
z275plus's Avatar
Does this mod help keep the engine cooler or is it just for looks ?
Old Feb 7, 2010 | 04:25 PM
  #21
doesnt help keep it cooler, just more for room for turbos ect. im just doing it for the extra room and a cleaner look in the bay. anyways, whats everyone using for fans? i got the 25241 rad, just waiting for a decent day to cut the car up. so what fans are you guys runnin who have done this? also the catch can, would that work? mounted right where the battery used to be? in trunk now..
Old Feb 7, 2010 | 05:52 PM
  #22
95mysticta's Avatar
Have a part number or dimensions for that first vertical radiator mod? I have been contemplating this mod myself to help clear up some room under the hood and also for a cleaner meaner look. Looks like a pretty easy mod and ill have my rad and fans out when i do the cam swap come spring time.
Old Feb 7, 2010 | 06:00 PM
  #23
in the post right before yours. 25241, search it on summit, its like 179 dollars. i think its like 1-25241-x or something like that, but 25241 is the main part number, made by griffin
Old Feb 8, 2010 | 08:04 AM
  #24
zzoomin's Avatar
Originally Posted by mzgp5x
OK... My app... 97ss 383ci LT1 MM6 w/ ATI-D1 blown w/ GZMS Vac pump mod.
Rad... A Summut BeCool stock size rad (larger than the typical Griffin).
Process... Cut top and bottom rad supports. Re-fabbed mounts.
Structure is like a rock. All fab and work my me over a winter.
No removal of the front facia during work.
http://s306.photobucket.com/albums/n...e%204th%20gen/
B.
looks good! I really like how clean it looks, and it looks like my morroso CAI would actually fit right w/ the rad like that. but now I'm going w/ a lid set up so standing the rad up is out of the question. but how do you not rip your air damn off like that?
Old Feb 8, 2010 | 08:22 AM
  #25
95mysticta's Avatar
Thanks for the part number! so going from the stock slant mounted rad does this take away from the cooling on it? Will this give me cooling issues moving it to vertical mounting?
Old Feb 8, 2010 | 03:05 PM
  #26
most guys say that it cools just fine if you do everything right. it is a 3 inch core rad so im sure that helps. anyways.... any one help me with the fans? please? haha part numbers would be awesome, but as always any help is appriciated. thanks alot guys!
Old Feb 8, 2010 | 08:45 PM
  #27
mzgp5x's Avatar
Yes zoomin. The rad air dam is lower, but the angle is steeper than stock. The air dam can be cut down to the stock clearance heigth (I did not do this). It clears OK for me, but can drag on some inclined drives unless you approach on an angle. Anyway, it has worked great, and I also run a Spearco IC inback of the air dam with an air scoop. It's a large rad (be_cool rad from Summit). I also run Evans cooling media NPG. Ice cold op temp. Hope this helps. B.
Old Feb 9, 2010 | 06:56 PM
  #28
i think ive decided to do mine just like kylers, just got the rad, but i just need to figure out what im doing for fans. anyy suggestions anyone? leaning towards modifing the flx 220 fans to fit the rad, anything else i can do? also what should i do for mounting, to hold the rad in place? thanks guys!
Old Feb 9, 2010 | 11:00 PM
  #29
94SLUG's Avatar
1 by1 square tube will be far stronger than what you see (the way its cut you loose 3 of 4 supports), not as clean looking but plenty strong.. I also added another 1by1 mid way down.. Not bashing, it looks great Kyle...
MZG that looks great too.... Some nice work fellas..
Old Feb 10, 2010 | 04:32 AM
  #30
i will most likely add something like that on the inside of whats left also, just for strength
