Vented Opti Swap Parts List
Old Mar 19, 2009 | 08:39 AM
silentsprintero's Avatar
I'm going to do a few tests today to make sure it is the opti but the car has 116k miles and I'm pretty sure it's had its time. I'll be doing the switch to the vented opti but every thread I have found links to http://para.noid.org/~muttvette/opti.html which doesn't exist anymore. Does this parts list look okay to you? I'll be ordering from GMpartsdirect.com most likely. I still have my stock cam from my '95 Z so I'll be using that. Anything else I should add to the list? Thanks!
1104032 95-97 Optispark (vented)
12130319 95-97 Optispark electrical harness (ordering from EFIconnection)
12555323 95-97 Optispark vent & vacuum harness
12552426 1995 Front cover (includes seals)
10474278 Optispark o-ring 2x
10483139 Ignition Control Module (may not need, but rather replace
everything while I am in there)
10128343 Water pump gasket
10128293 Front cover gasket
10128485 Stock timing chain
10206039 Stock cam sprocket
10128346 Stock crank sprocket
Old Mar 19, 2009 | 09:29 AM
96capricemgr's Avatar
The MDS cap and rotor kit would retrofit your opti to make it vented. Would be a lot cheaper and easier.
Old Mar 19, 2009 | 01:18 PM
I've heard good and bad things about this... Since 2005 has there actually been improvements in the design? If so I might just get the cap and rotor, water pump and new opti harness.
Old Mar 19, 2009 | 02:18 PM
I would not run the MSD whole opti if it were given too me, the cap and rotor seem to be fine though.
*Emilia*
May 13, 2015 09:05 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Nov 20, 2014 06:32 AM
SaxRulez
Jun 12, 2004 09:29 PM
dobe
Jul 31, 2002 01:28 PM
