Vented opti Install
Old Mar 11, 2004 | 01:25 PM
ibanez6rg's Avatar
Vented opti Install
How much force should be used when installing one? Mines not going in as easy as I thought it would. I don't really feel like breaking anything.
Old Mar 11, 2004 | 01:44 PM
speedmiser's Avatar
Non-vented - should slide in easy if the splined shaft is seated correctly in the opti and the timing gear keyway.
Vented - May take a slight push to get the shaft (w/ o-ring) to slide into the hole in the cam face. Put a little oil on the o-ring and it should slide in without much force. If you've got to shove hard, then something is not lined up right.
Old Mar 11, 2004 | 01:49 PM
ibanez6rg's Avatar
Yea I figured the vented should be a little holder with it going into the cam face. I'll try putting a little oil on the o-rings. Thanks.
*Emilia*
May 13, 2015 09:05 AM
thenewkid
Nov 27, 2014 09:41 AM
GigaMp3z
Feb 20, 2003 02:57 PM
