Vented opti Install
Non-vented - should slide in easy if the splined shaft is seated correctly in the opti and the timing gear keyway.
Vented - May take a slight push to get the shaft (w/ o-ring) to slide into the hole in the cam face. Put a little oil on the o-ring and it should slide in without much force. If you've got to shove hard, then something is not lined up right.
stockssn2o
May 25, 2015 08:54 AM
