venom computer module
Old Mar 23, 2005 | 10:21 PM
terrible 1's Avatar
venom 400 performance control module
so whats the deal with the venom comp module? it advertised 25% hp&tq increase. will it do it? is it worth the money? is it better than a stage 2 chip? thanks.
Old Mar 24, 2005 | 03:08 PM
terrible 1's Avatar
Re: venom computer module
someone has to know somthing about it.
Old Mar 24, 2005 | 04:19 PM
mourningyou's Avatar
put up a link, it's probably bs tho.
Old Mar 24, 2005 | 06:28 PM
terrible 1's Avatar
heres one of many sites. http://store.directauto.com/ven400percon.html
Old Mar 24, 2005 | 06:54 PM
30696bird's Avatar
I'm gonna have to call , there is noway that will give you 25%!
Old Mar 24, 2005 | 09:41 PM
it's probably just a maf translator or intake air temp box, but after reading it more closely, it looks like it just makes power enrichment mode come on much easier.
Old Mar 24, 2005 | 09:50 PM
Bow94z's Avatar
sounds like something they would sell to ricers...but im gonna have to go with the aboce post as a maf translator
Old Mar 25, 2005 | 08:46 AM
ShawnMacAnanny's Avatar
A Jet Stage 2 chip? I had one, they are next best to getting a computer tune but twice as much and not as good.
Old Mar 25, 2005 | 09:57 AM
97Z-M6's Avatar
the pe mode is enabled by the tps, so thats not it, but i think your right about maf translator
if your going to buy anything pcm now days you might as well just buy tunercat and be done with it you can get tunercat and the cable for 165 and do a 1000 times more things than that peice of crap.
Old Mar 25, 2005 | 04:44 PM
Originally Posted by Venom PCM Link
The Venom 400 activates at about 25-30% throttle angle. Upon activation it modifies the input signals going into your computer, in particular the Manifold Absolute Pressure and Throttle Position Sensor Signals.
its just a maf translator and a pe translator. lets you use PE mode with the throttle blades more closed. probably wastes a ton of gas :P
PopoFormula
Oct 12, 2015 04:19 PM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
