vats wiring
Old Mar 6, 2005 | 01:11 PM
gillt1's Avatar
Question vats wiring
Has anyone have picture of wiring vats bypass module? I have schematic but donot understand taht well. Thank You.
Old Mar 6, 2005 | 01:17 PM
RE AND CHERYL's Avatar
Re: vats wiring
It's actually pretty easy. Use a miltimeter to measure the resistance in your key. Get a resistor that matches the resistance of your key and tap it into the wires going to the vatts contacts in the ignition lock.
Why do you want to bypass it??
Old Mar 6, 2005 | 02:10 PM
gillt1's Avatar
Re: vats wiring
Maybe I worded my question incorrectly. I purchased vats bypass module form Bakerelectronix. ,they sent a wiring schematic , but I cannot understand diagram, this why I would like picture of diagram. Thank You in advance.
Old Mar 6, 2005 | 09:36 PM
Re: vats wiring
Without seeing their diagram, it's a little hard to know exactly what they are telling you. I assume you don't mean the key pellet bypass, but the VATS module bypass (that simulates the modulated ground signal to the PCM).
Old Mar 7, 2005 | 06:48 PM
gillt1's Avatar
Talking Re: vats wiring
Thanks all ,I did some research and found what I needed
Heathen1
Jan 2, 2016 04:27 PM
Klypto
Mar 9, 2015 04:25 PM
Noer
Feb 28, 2015 11:29 AM
Lakebratt
Feb 5, 2015 07:55 PM
Fedesna
Nov 23, 2014 11:06 AM
