VATS/Starting problem
Old Aug 14, 2006 | 07:59 AM
  #16
Re: VATS/Starting problem
Originally Posted by rwmj5
here is a great question that I have never seen answered satisfactorily- Where the heck is the actual VATS/Theft deterrent module located?
I've heard all sorts of descriptions of "its sort of under the dash by the glovebox." I've heard "its on the left side of the glovebox". Ive heard the opposite: "Its under the dash to the right of the glovebox."
Where is it really located? I have seen no pictures of it or where it is located. People have said 'I swapped out my VATS module and everything worked fine' but there has only been ambiguous descriptions as to how they got to it. I've even seen people on here ask where it is, and the question was totally ignored. It seems to be a mystery for some reason.
So where is the theft deterrent/VATS module REALLY? Does anyone have any photos of its location, or even any photos of it by itself, or at least have a worthwhile description of where it is and how to get to it?
The TDM is behind the glovebox. The TDR is to the right of the glovebox. Two different things.
Old Aug 14, 2006 | 08:00 AM
  #17
Originally Posted by Dave89IROC
by shutting down the injectors, but not the pump, IIRC
I have not been able to fully verify which way it is done.
Old Aug 14, 2006 | 04:08 PM
  #18
Dave89IROC's Avatar
agreed, I know for sure it is injectors and starter in thrid gens, and the 93, but not positive in the 94+ cars
would be easy to check, just need to get around to it
heck, if I come across a PCM for a 94, I'll check, in the swap I put a 94 LT1 in my K5, the fuel pump is not run from the PCM, so if it doesn't run with a PCM w/VATS, we'll know
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
