vats problem
Old Nov 5, 2006 | 01:09 PM
slimdem25's Avatar
vats problem
i changed out my steering colum and now mt security light is on and my car wont crank..does anyone know how to dissable my VATS on my camaro ?
Old Nov 5, 2006 | 03:06 PM
oneslowz28's Avatar
You have 2 options. You can have it programed out of the computer by one of the mail order tune places or you can use this write up to do it your self. http://shbox.com/1/vats_bypass.jpg
use this to find the pellet resistance.
http://shbox.com/1/4th_gen_tech2.html#pass_key
Old Nov 5, 2006 | 08:14 PM
superduper's Avatar
There is option 3, Baker electronics on ebay sells a bypass box for 25.00. It is a 3 wire hook up and has not given me any issues. Very simple and took a couple of days to get it.
Old Nov 5, 2006 | 08:31 PM
oneslowz28's Avatar
why spend 25 bucks on the box when you could spend 99 cents on a resistor and just solder it in cover in heatshrink and be done with it. 10 min and 99 cents sounds much better than 25 bucks and a few days.
Old Nov 5, 2006 | 08:41 PM
superduper's Avatar
Just an option, he can do what he wants.
Old Nov 5, 2006 | 09:14 PM
He does not need that module if it's only his key pellet that is not being read. He needs the resistor bypass. The theft deterrent relay still won't work if he bought that module.
Old Nov 5, 2006 | 10:01 PM
superduper's Avatar
The module bypasses the pellet and the vats module and gives the pcm the signal for fuel enable. I have used them in the past and have never had a prob. The vats in a 97 lt1 is through the BCM and it also gave the signal for fuel enable. There was no way to get the pellet resistance since I had no key and there for used the module.
Old Nov 5, 2006 | 10:13 PM
oneslowz28's Avatar
Im sticking with the resistor and theft deturrent relay bypass. much faster and much cheaper. It takes 2 min to solder the resistor in and 5 min to bypass the relay. the other 3 min are used for drinking beer.
Old Nov 5, 2006 | 10:48 PM
Perhaps that module sends a ground to the TDR, too. It does not really say in their description. I know all about the BCM, fuel enable and such.
Heathen1
Jan 2, 2016 04:27 PM
Klypto
Mar 9, 2015 04:25 PM
Noer
Feb 28, 2015 11:29 AM
Lakebratt
Feb 5, 2015 07:55 PM
Fedesna
Nov 23, 2014 11:06 AM
