Vats????? Need Answers Quick
Old Aug 14, 2003 | 07:39 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
car was running aboslutly perfectly... then i removed the stereo... now car won't run, turn the key... NOTHING not a light, ding, sound, nothing... as if the car didn't even have a battery connected to it
is that VATS?
or,,,,,,,???
how hard is it to get around the VATS?
Old Aug 14, 2003 | 08:33 AM
KCFormula's Avatar
First I would hook a multi-meter to your batt. and find out if it is just a coincidence that your batt. might be dead.
The by-pass the vatts you must pull apart under your steering console and place a resistor between the wires, its kinda a PITA. I would first check the battery then go ahead and check the resistance in the chip in your key.
Old Aug 14, 2003 | 08:38 AM
Check your fuses. Pulling the radio should have nothing to do with VATS. The problem is probably self-inflicted.
Old Aug 14, 2003 | 09:19 AM
Jesse_Boyer's Avatar
something says its a connection at the battery. Even if you fubar'd a fuse/relay, you should still have SOMETHING that would be hot. Try turning the headlights on
Old Aug 14, 2003 | 09:45 AM
frmula1's Avatar
headlights are out and sold
checked all the fuses inside and in the engine bay... they are all fine.
battery connection was mint.
resistors on BOTH keys are fine
i guess i'll have to jump start er' to see if it was the battery (probably)
so i guess my question is now...
would taking out the stereo and triggering the vats prevent the car from starting if there were no other problems anywhere?
68camaroboltz
Oct 5, 2015 11:56 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
NewsBot
Sep 14, 2015 09:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
