Valvetrain questions
Old Sep 28, 2008 | 11:02 PM
Tex95Z's Avatar
Hey all, I have a couple questions. My A4 tranny on my 95 Z has recently went out, Im pretty sure Im going to convert my car to an M6 fairly quickly. I know Im going to need to get a tune for the swap, so I figure I might as swap the cam out as well.
Im planning on going with the CC503, as that cam seems to be about the biggest, usable cam for my stock bottom end, or something similar. I will be using some type of PAC springs as I see alot of good reviews on their products, and some 1.6 roller rockers. Later on down the line (next summer) I plan on getting a better than stock set of heads, more than likely something from Lloyd.
Having said that I have a few questions.
1. Which Pac springs should I be looking at?
2. Would 30# injectors be of any benefit for this setup?
3. If I install the 1.6RR's will I need to get a different size pushrod?
4. Will my stock lifters work for this setup?
Thank You in advance.
Old Sep 29, 2008 | 07:06 AM
rskrause's Avatar
Moderator
http://www.pacracing.com/beehive.html PN 1218 and 1215 have about the right specs
No
Theoretically yes, but you could probably get away with the stockers. You will have to mock it up and see how far the new setup is off center.
Yes
Rich
Old Sep 29, 2008 | 05:59 PM
Tex95Z's Avatar
Thank You Rich.
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
