Valvetrain Questions
Old Apr 27, 2003 | 07:32 PM
ZaneO's Avatar
I have 86k miles and a fair amount of valvetrain noise. I plan on getting some new valve springs and probably roller rockers, too.
My question is, at 86k should I be concerned with my lifters? Could that be the noise I am hearing (pretty sure it's the LT1 ticking lifter noise)? What would you guys recommend?
TIA
Old Apr 27, 2003 | 08:22 PM
T/A#4's Avatar
I had the same problem. A fellow that I know who builds hot engines suggested that I add CD2 High Detergent to my oil when it's clean. Presto noise is gone Seems if your car sits a lot, things gum up even with fresh oil. If yours is a scond car that may be the problem ? Otherwise try a valve adjustment as these cars are a b_ _ _h to work on !
Old Apr 27, 2003 | 09:51 PM
ZaneO's Avatar
The intake HAS to come off to do the lifters, correct?
Old Apr 29, 2003 | 05:02 PM
ZaneO's Avatar
Anymore suggestions?
Old Apr 29, 2003 | 05:07 PM
Don 97 SS's Avatar
Yes.
If you are on a budget do the springs and RRs. Be certain to adjust the RRs/vavlves properly and maybe that will address the noise you are hearing.
A good set of lifters is about $200 and Fel-Pro intake gaskets are about $25 and may not be necessary.
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
