Valvetrain Questions
I have 86k miles and a fair amount of valvetrain noise. I plan on getting some new valve springs and probably roller rockers, too.
My question is, at 86k should I be concerned with my lifters? Could that be the noise I am hearing (pretty sure it's the LT1 ticking lifter noise)? What would you guys recommend? TIA |
I had the same problem. A fellow that I know who builds hot engines suggested that I add CD2 High Detergent to my oil when it's clean. Presto noise is gone :bow: Seems if your car sits a lot, things gum up even with fresh oil. If yours is a scond car that may be the problem ? Otherwise try a valve adjustment as these cars are a b_ _ _h to work on !
The intake HAS to come off to do the lifters, correct?
Anymore suggestions?
Originally posted by ZaneO The intake HAS to come off to do the lifters, correct? If you are on a budget do the springs and RRs. Be certain to adjust the RRs/vavlves properly and maybe that will address the noise you are hearing. A good set of lifters is about $200 and Fel-Pro intake gaskets are about $25 and may not be necessary. |
