Valves questions...help
Old Oct 6, 2005 | 01:33 PM
1crazylt1's Avatar
Ok so i was driven my car and my timing chain just snapped..would this cuz my valves to b bent??
Old Oct 6, 2005 | 02:03 PM
KrazedZ's Avatar
Re: Valves questions...help
Yup, camshaft stops moving which doesn't move your valve train while your rotating assembly is still spinning and eventually the piston collides into your valves that are stuck open.
Old Oct 6, 2005 | 04:08 PM
1crazylt1's Avatar
so is changing the valves hard or is the motor shot??
Old Oct 6, 2005 | 05:35 PM
1racerdude's Avatar
If it didn't hurt the pistons or the rod bearings it will be OK. The brgs need to be checked and a good look taken of the pistons and replace the valves and pushrods that are bent.
Old Oct 6, 2005 | 08:43 PM
1crazylt1's Avatar
most deffenitly my valves would b bent..
Old Oct 6, 2005 | 09:10 PM
1crazylt1's Avatar
Now if i was to order valves would i order intake or exhaust or both??
Old Oct 6, 2005 | 09:12 PM
1racerdude's Avatar
Ya need to weight until it is torn down to see what is bent. Ya may not need a full set of each.
Old Oct 6, 2005 | 09:18 PM
1crazylt1's Avatar
how do i go bout checkin if their bent no clue on how to check them is thier a tech page
Old Oct 6, 2005 | 09:35 PM
1racerdude's Avatar
They will be bent enough ya can see it. On the others get some solvent(mineral spirits) and fill up the ports I&E and see if they leak. This is off the car on the bench.
Old Oct 7, 2005 | 05:27 AM
1crazylt1's Avatar
will try
Old Oct 7, 2005 | 06:07 AM
cehan's Avatar
If you don't already have it torn down, replace the timing chain and do a compression check. That should show you which cylinders have the bent valves.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
