Valves questions...help
Re: Valves questions...help
Yup, camshaft stops moving which doesn't move your valve train while your rotating assembly is still spinning and eventually the piston collides into your valves that are stuck open.
Originally Posted by 1crazylt1
so is changing the valves hard or is the motor shot??
Now if i was to order valves would i order intake or exhaust or both??
how do i go bout checkin if their bent no clue on how to check them is thier a tech page
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
