Valve and Valve seat sizing
Old Feb 10, 2004 | 07:34 PM
sandmanljs's Avatar
If tryed asking this to lots of diffrent peple, with lots of doffrent answers.
Can I use a 2.00 intake and 1.56 inch valve in a LT1 head with the stock valve seats?? Thanks in advance
Old Feb 10, 2004 | 07:48 PM
kmook's Avatar
Advanced Tech Moderator
Yes. I've run 2.02/1.60.
This thread http://web.camaross.com/forums/showt...hreadid=152605 confirms this from a few members that are engine builders/head porters.
BTW- This should be asked in LT1 Tech. Transfering.
Old Feb 10, 2004 | 08:58 PM
sandmanljs's Avatar
Thanks. Glad I can, hopefully I can actually do it at school.
I tryed the LT1 forum a few times with no real good answers. Thanks again.
Old Feb 11, 2004 | 03:40 AM
NightTrain66's Avatar
The stock seats in the LT1 heads can only be machined "so big" and they work perfect with 2.00/1.56 valves, if you use a 2.02/1.60 valve, you are basically placing a slightly larger valve in front of the same size seat. This DEFINITELY doesn't help flow.
The only reason to use the 2.02/1.60's would be the price. These sizes are alot more common and can be bought for less $$$. The 2.00/1.56 valves are a lil more $$$ but fit and flow better.
Lloyd,
NightTrain66
Old Feb 11, 2004 | 04:14 PM
sandmanljs's Avatar
How much flow would I pick up going with the 2.00 and 1.56 combo over the stock valves with a 3 angle valve job? Would it be worth the cost for a very very budgeted build? THanks.
Old Feb 11, 2004 | 09:38 PM
depends on the exact budget and what you would be giving up to opay the other $60-100 for 2.00/1.56 valves. If the $60-100 means that you do not have larger injectors or good tuning in the budget, use the cheeper valves. if you can come up with the extra $$$, it is worth it. Not sure of an exact HP # but it would be very small.
Lloyd
NightTrain66@msn.com
HectorM52
Jul 30, 2017 11:46 AM
BIGCOWL-IMP
Feb 7, 2015 06:10 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Timberwolf
Jul 30, 2002 08:31 PM
