Valve Stem Seal?
Old Jan 14, 2009 | 02:08 PM
DAVE00's Avatar
Valve Stem Seal?
Guys,
I'm having the springs changed when I do the cam swap next month, so I completely forgot but it's probably a good time/insurance to go ahead and change my valve stem seals. Anyone recc a certain brand, type (rubber, teflon, viton, etc...) and size I need to go with.
Here are the specs of my heads and springs:
AFR 190s (1.800 installed spring height)
Intake valve (2.020 standard length)
Exhaust valve (1.600 standard lenght)
Springs - Howards 98441 (id: .800 and od: 1.437) (These are the one's going on)
Not sure if you need all this info, but just looking for a good set of seals that work great. Part numbers or links if you have em please. Thanks.
Old Jan 14, 2009 | 02:50 PM
RamAir95TA's Avatar
I have had nothing but bad luck with the K-line seals. I recommend the viton seals.
Old Jan 14, 2009 | 03:02 PM
Viton is what I would use.
Old Jan 14, 2009 | 10:44 PM
DAVE00's Avatar
Double checked and the seals that AFR uses today and the same part # I have from AFR is for .530" guides and 11/32 size for valve stem. I am thinking about these from Comp, what du u guys think?
http://www.jegs.com/i/Comp+Cams/249/529-16/10002/-1
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
camaro02DK
Jul 5, 2015 09:24 AM
KamikaZ28
May 28, 2015 12:45 AM
